- Joined
- 6 Nov 2003
- Messages
- 327
- Reaction score
- 4
- Country
I get what you are saying but valve brown wire goes first to the connection hub in the loft next to it then that is connected to the old cable which went down the the thermostat (which has now been cut out).That is because the connection used to come via the old room thermostat, just connect as I said, the hive opens the valve, the valve sends power to the boiler and pump not the hive
does that make sense? So I can’t get a feed from the CH on up to the valve unless there is a spare wire on the current other wiring which I can’t see there is.
