- Joined
- 8 May 2017
- Messages
- 10,676
- Reaction score
- 2,877
- Country
I suspect your non return valves are sticking ,and possibly shower filters partially blocked.
Is the non return valve and filter in the mixer barrel ? Is it a matter of fixing or replacing the non return valve?I suspect your non return valves are sticking ,and possibly shower filters partially blocked.
They are within the shower, usually where the supply pipes connect to the valve. Stripping,servicing required .Is the non return valve and filter in the mixer barrel ? Is it a matter of fixing or replacing the non return valve?
The supply pipes are behind the wall but poke out enough to attach the mixer shower barrelThey are within the shower, usually where the supply pipes connect to the valve. Stripping,servicing required .
Show us a pic of the shower valve.
should on previous post now - internet was slowPics ??
Hi Terry, I have a similar problem to this. I have a new shower and the filters are not blocked. There is a pump fitted for to pump the water from the tank. When I turn on the water valve on the shower, no water comes out. However if I switch on the tap in the sink the water then comes out of the shower. Sometimes if I put the shower head closer to the floor the water in the shower does come out. Any ideas how to resolve this issue without getting a new water pump? Thanks, JimYour hot water is gravity fed ,and pressure would be poor ,hence a pump has been fitted . There is insufficient water flow through the shower to trigger the pump . This could be the shower head itself ,or the flexible hose are too restrictive to flow. Remove the shower head and let the hose hang down .Then run the shower and see if pump now starts.
You probably need a negative head pump of if the new one is negative head, the pressure vessel may need pumping.Hi Terry, I have a similar problem to this. I have a new shower and the filters are not blocked. There is a pump fitted for to pump the water from the tank. When I turn on the water valve on the shower, no water comes out. However if I switch on the tap in the sink the water then comes out of the shower. Sometimes if I put the shower head closer to the floor the water in the shower does come out. Any ideas how to resolve this issue without getting a new water pump? Thanks, Jim
