Morning,
We have a UFH system which was fitted maybe 9 years ago that has developed a few little leaks around the manifold - one on an un-used flow meter (see pics attached) and one from a thermostat fitted to (what I assume is) the mixer manifold? There is another from the Magnatrol connections above the manifold, but I can sort that fine.
Im happy I can remove and plug the leaking flow meter, but the thermostat is of more concern as there is a constant drip from the bottom of the plastic part where is screw in to the mixer.
Does anyone have an idea what the make of this mixer is so I can source a replacement mixer or thermostat?
Secondly, there doesnt appear to be any isolation valves in the 22mm pipes connected to the mixer- would I have to drain the system back to the boiler (which is about 30m away outside the house?
Any assistance or recommendations would be greatly appreciated
