I have an Envirovent extractor fan with run-on timer, i.e. it has neutral, switched live and an extra unswitched live to power the run-on. I want to use it with a touch switch but it doesn't work. It will switch on OK but automatically switches off after a couple of seconds. The run-on works as it should so the fan keeps running for a minute. I've tried it with both a Livolo and an iLumos switch and both are the same. If wired up to a conventional on/off rocker switch it works perfectly so there's nothing wrong with the fan.
The fan uses 8w. Do you think this means there is insufficient current for the switch to detect that it's on, which is why it switches off immediately? The specs for the Livolo say it works with 3 - 1000w but I'm sure I read somewhere that other people have had trouble with low-wattage appliances and touch switches.
Alan
Alan
