- Joined
- 16 Sep 2021
- Messages
- 19
- Reaction score
- 0
- Country
Tightening those seemed to have stopped that
So are you leak free now?Tightening those seemed to have stopped that
No it shouldn’t go that high during normal use, you have an expansion problem and need a gas safe registered engineer to sort. Just double check before you engage with one, that you’ve turned the filling loop off and it’s not passing - to check the latter, disconnect the loop at the check valve side (left had valve).Is this to be expected or do I need to do something about that?
No ignore the valve you haven’t touched yet in terms of trying to turn it on or off, just the nut that connects to it, disconnect it and see if water trickles from out of the hose, more than an eggcup full and doesn’t stop and it’s likely passing. Yes you understand it correctly the filling loop is the valve you used to add pressure. I doubt you’ve overshot the pressure, especially to go as high as it has, even with settlement.Thanks CBW. Just so I understand. The filling loop being turned off is to do with that original valve I turned to add the pressure?
So tomcheck this I turn the other side (left side) off. The one I haven't touched yet?
