It enables a greater range of tarrifs
But, what they've done with "smart" meters is not required for that. All they need to collect is ONE register total per charging rate per charging period - so that might be (picking a number) say 20 or 30 totals in a month. It does not need 48 readings PER DAY. So there's a privacy issue there that TPTB seem "reluctant" to address - fundamental rule of privacy, if you don't collect it then it can't be misused.
For a while I saw a bunch of people praising octopus's agile tarriff
Yes, the poster child of what smart metering can do - except that it doesn't
The smart meter plays zero part in conveying charging rates to users - that's done over the internet and is predicted the day before. So it's not real-time, and the smart meter is nothing more than a multi-register meter designed in the least privacy protecting manner possible.
AIUI, the spec for the smart meters doesn't actually include the level of detail needed to create such a system without a side channel (i.e. the internet) to pass out the future charge rates to allow decisions on usage - which is a monumental fail (one of many) really.
I do wonder if with the rise of solar and EVs, we will reach a time when power in the middle of the day is cheaper than the middle of the night
Less expensive might be a better way of putting it
As things stand, it's not very common to be burning no fossil fuels and that's going to get worse as what's left of our nuclear stations finally get shut down. For some short periods, during low demand days, when there is lots of sun, and the right sort of wind is blowing - then we have an over supply. But most of the time, we're still reliant on gas.
EDIT: And as for our imports, until the whole of Europe also gets to zero fossil fuel (and note how Germany shut down it's nukes in favour of importing dirty coal generation from Poland), then they aren't green either.
Rather than turning off whole neighbourhoods at once. Of course the powers that be are keeping very quiet about that feature because they don't want to discourage adoption.
Exactly, they never mention that. 1974 here we come again - get the candles out
Would they ever do that ?
Well they say they won't, and they say they'll only cut off non-paying customers after all the same legal process ...
It does make it easy to cut off the none payers, without having to gain or force entry - but that would only be after numerous warnings.
It's lucky that utility companies never make mistakes.
Exactly. It's not like there aren't plenty of stories of suppliers "getting it massively wrong" and then finding themselves totally unable to resolve the matter even though it's quite unrealistic for (e.g.) a domestic customer to have run up a million quids worth of debt for their lecky.
The very fact that currently it needs physical access means "outside eyes" looking at the situation - whereas we are completely confident that no part of the process could ever get sidelined in the pursuit of corporate convenience aren't we
although one thing which it seems is being done, is to have EV charging which can be switched off remotely.
Which again doesn't need smart meters, and I strongly suspect that it actually doesn't involve them.
So in the future there is a possibility that we could set a time by which the EV needs to be charged, and the supply can be altered so keeping an even load on the generators by adjusting EV charging rates.
Yes, but smart meters as implemented don't have that capability
There has already been reports of an error resulting in wrong smart meter being turned off, it really does not matter if true of false, if people think it may be turned off in error they are not going to get one
TBH, I would be amazed if it's not heppened yet.
if not being used why fit it.
Don't forget that these meters can also be pre-pay meters - in which case they need to turn off the supply when you run out of credit.
I am told in France there is a very low rated fuse or MCB on the incomer and you pay according to maximum supply current
Correct, and also in Spain and Italy. At a previous job we had an office in italy - they used to have regular power cuts if they managed to mismanage demand (like running the air con).
But the point is the adverts clearly are not telling the truth
It's an advert, their purpose isn't to tell the truth
QUOTE="scousespark, post: 5068287, member: 27765"]It's an acronym - 'Self-Monitoring, Analysis and Reporting Technology'[/QUOTE]
Or it's Specific, Measurable, Achievable, Realistic, and Timed - at least if you're talking about performance management and setting objectives. But that's a different thread hijack.
