2 Google Nest Thermostats for 2 zones connected to Intergas Rapid 32kw
4 Apr 2008
Glasgow
I would like to connect 2 Google Nest Thermostats for 2 zones to an Intergas Rapid 32kw (used as a combi boiler).
Below is the wiring for the Nest as provided by Google:
Page 63 of the Intergas Rapid 32kw manual shows that the Live and Neutral are on pins 2 and 4 of the X2 connector (refer to screenshot below).
Is this just a matter of connecting both Nest Heat Links as per above diagram and connect the Live and Neutral to pins 2 and 4 of the X2 connector on the Intergas boiler?
Is this really as simple as that?
Your Switch Live goes to Terminal 1 on X2
I added the terminal # of the boiler (in red) on the diagram below, is this what you mean?
Brilliant Andrew, thanks a lot!
PS: regarding the pump inside the combi boiler, do terminal 7 & 8 really need to be connected to Live and Neutral?
Sorry for the silly question, but if I do so I assume the pump will be constantly turned on, shall this actually be Switch Live on terminal 7?
The boiler's PCB deals with switching the pump, you don't need to connect anything to that
I should have added that the jumper wire between terminals 6 and 7 of connector x4 (installed by default) needs to be removed.
