Hi all,
I've been lurker of these forums as there is a wide range of helpful information.
I'm coming to the end of a stressful kitchen extension having had issues with the builders. We've got electric underfloor heating installed on the ground floor of or house which has worked fine for the last couple of years. We decided to install the same warmup foil mat in our kitchen.
Now, I decided to test the heating. The thermostat turns on fine, allowed me to set the time etc then when the relay kicked in to warm it, it tripped the electrics. This got me really worried.
I've checked with my multimeter and the ohms reading between L N is within tolerance, however its detected earth leakage from both L N to ground. The multimeter was set at 2m ohms and when I test leakage the figure jumps and then stays at 1.
I remember the builder caused a huge leak in our kitchen when installing the water softener a month ago. We upgraded our mains to 32mm so you could imagine how much water gushed out. He tried to clear as much as possible. Last week there was a leak from the boiler area where the copper pipe was under tension going in to a push fit. That was fixed but again water was on the floor, especially around the edges. The water has most likely seeped under the floor.
My gut feeling is that I have to pull up the floor (waterproof laminate) but how can I do this when all the units and worktops have been installed? Do I have any other option? It's very depressing having waited so long after continuous issues. Should I call a specialist? I'm not sure what they would be able to do tbh in this scenario.
Any help or advice is much appreciated.
