I spent quite a lot of money (for me anyway) on some cast aluminium guttering which I finally got around to fitting & noticed the lengths were pretty warped & seem to splay out more open at the if that makes sense & the ends are WAY out of square. I emailed the company & got a response saying:
"the same as cast iron, the victorian system chosen does 'lean forward’"
"Cast guttering system are the traditional, oldy worldy feel systems are are not designed to look perfect"
"Cast aluminium systems should be installed on fascia brackets"
Now I'll admit I chose not to use brackets out of personal preference, but brackets would not have any affect on the shape of the guttering which is solid & dose not bend when even when considerable pressure is applied. I'll add some photos bellow, let me know if you think I'm expecting to much or the product is bellow par
