Cartridges on 3 hole mixer tap
18 Mar 2018
Has anyone changed the tap cartridges on this tap?
No, I haven't, and this might not help! :)
But it looks like you have all the information you need there!
Is there anything in particular you wanted to know?
Personally, I have found it much easier to take the cartridge out and measure it properly to find a replacement.
However, as many on here will testify, often taking the cartridge out and leaving it to soak in some descaler, will bring it back to life! :)
Thanks just wondered if the is usually something to hold back on from above to remove the cartridge. And if they usually come out ok. Is around 18 years old.
I would have a go and see what happens!
After 18 years they may be a bit crudded up though.
A liberal soaking of WD40 may help.
And although I can't vouch for the quality, similar replacements are available for around £70. Not cheap, but worth it to save hassle?
https://www.amazon.co.uk/Kelelife-Handles-Widespread-Bathroom-Polished/dp/B07NKX4FGK
EDIT: maybe not, this one doesn't have a pop-up waste and the reviews aren't the best!
Good luck :)
Good luck :)
Are most 3 tap hole taps the same pipe centres. 200mm between the taps with the spout in the middle?
