    Dismiss Notice
Mixer tap still leaking after changing ceramic cartridge
Discussion in 'Plumbing and Central Heating' started by millie900, 3 Mar 2020.
  1. millie900
    millie900
    12 Jul 2011
    16
    Thanks Received:
    2
    Fife
    Country:
    HI everyone,
    could someone please offer some guidance please on having replaced the bat mixer tap cartridges, the hot is still leaking? It is in fact worse than it was prior to cartridge change! Pushing down on the top of the cartridge actually stops the drip, but can't keep the pressure on it with the tap cover. Is it time to change the whole tap unit do you think?
    Any clues please?
    TIA
    Millie
  2. Burnerman
    Burnerman
    7 Feb 2008
    20,882
    Thanks Received:
    4,050
    Northumberland
    Country:
    Did you notice a rubber washer on the end of the insert, Millie?
    If its not there, or the insert isn’t the exact same size the leak won’t stop.
    John :)
  3. millie900
    millie900
    12 Jul 2011
    16
    Thanks Received:
    2
    Fife
    Country:
    Hi John,
    thanks for your reply. Took the old cartridge to screwfix and asked for new one to stop the leak :D The red rubber washer definitely in place, do those washers come in differing depths?
    M
  4. Burnerman
    Burnerman
    7 Feb 2008
    20,882
    Thanks Received:
    4,050
    Northumberland
    Country:
    Not as far as I know, but the new cartridge must be exactly the same length as the original one.....if it isn’t it just cant seal in the tap body.
    Can you compare the two, side by side?
    John :)
  5. millie900
    millie900
    12 Jul 2011
    16
    Thanks Received:
    2
    Fife
    Country:
    Thanks John, that makes sense, but without callipers, can't measure the difference, as looking at them they appear to be the same. Do different tap manufacturers have specific cartridges by any chance?
    M:)
  6. Burnerman
    Burnerman
    7 Feb 2008
    20,882
    Thanks Received:
    4,050
    Northumberland
    Country:
    Indeed they do, and there are many variations unfortunately.
    One of the best suppliers are lunns.net and they have a good website with pictures and dimensions.
    As a general guide, the new cartridge needs to be within 0.5mm in length compared with the old one to fit properly.
    John :)
  7. Sponsored Links
  8. millie900
    millie900
    12 Jul 2011
    16
    Thanks Received:
    2
    Fife
    Country:
    John, that's really helpful thank you very much (y)
    I will investigate later. As ever these things happen at the most inopportune times - am desperately putting together a PhD application and academic CV ready for deadline tomorrow midday.....it's going to be an all-nighter I think
    thanks again
    M
  9. Chris_W
    Chris_W
    26 Sep 2019
    2,626
    Thanks Received:
    737
    North
    Country:
    Not ideal, but what I've seen some of our customers do to stop a drip is use an elastic band or hair bobble to put the pressure on.
    • Thanks Thanks x 1
  10. Burnerman
    Burnerman
    7 Feb 2008
    20,882
    Thanks Received:
    4,050
    Northumberland
    Country:
    Sounds like a dripping tap is the least of your worries, Millie.....
    Prioritise your education - the tap can wait!
    John :)
  11. millie900
    millie900
    12 Jul 2011
    16
    Thanks Received:
    2
    Fife
    Country:
    Thanks John :)
    I am shall we say a more mature student who ought to know better than to put herself through this amount of stress at this time of life :rolleyes::LOL:
    M
  12. Burnerman
    Burnerman
    7 Feb 2008
    20,882
    Thanks Received:
    4,050
    Northumberland
    Country:
    Education is never wasted....apart from on some of us when we were young! I'd jump at the chance to do engineering research again.
    Good luck with that, and also the taps....don't dwell too long on them - bite the bullet and go for a replacement quality set if you get grief.
    John :)
    • Thanks Thanks x 1
  13. millie900
    millie900
    12 Jul 2011
    16
    Thanks Received:
    2
    Fife
    Country:
    Ironically, the tap is now sorted, albeit using the 'cold' replacement cartridge so it turns the wrong way. We don't use the bath anyway so not a problem at the moment. Will source the better quality replacement parts at a later date. Thanks for the info about the online source.
    Well, PhD application has been submitted. I am (very) late to real academia, qualified last year as a nurse, currently completing an MSc, and plan to get onto a PhD studentship. Definite mid-life crisis, but loving the research aspect and the ability to influence and hopefully change healthcare policy and service delivery. I am too old for firefighting on understaffed and overstretched wards:rolleyes:
    Never too old to go into research, there are loads of opportunities - go for it.
    M
    • Thanks Thanks x 2
Loading...
Share This Page
