All outputs from my cooker panel (Cooker and 13 amp socket) are dead.
The circuit is: Consumer Unit to the original Cooker Panel location in kitchen, which is now a
standard wall box from which a 30amp cable has been extended to a new Cooker Panel where the cooker is now located.
This has been working perfectly for over fourty years.
When this first happened last week, I checked the terminals in the wall box and obtained a reading of 155 volts. (the Consumer Unit fuse was sound but I cleaned the fuse contacts anyway.
I refitted the cover plates while I gave the matter some thought and, shortly after, everything started working.
A week later (today) the Cooker Panel has gone dead and again the reading at the wall box
is 155 volts.
No wiring in the circuit has been touched at any time other than prodding with the meter probes.
All lighting circuits and the ring main are working properly.
Can anyone advise me as to what the fault could be please ?
Thank you.
is 155 volts.
Thank you.
