- Joined
- 27 Oct 2021
- Messages
- 5
- Reaction score
- 0
- Country
Hello Everyone,
I bought the Hive Thermostat System (Heating Only). My current boiler is Worcester Greenstar 24I Junior. The current installation has a separate mains power supply to Boiler. Picture Below
And then there is another wire from boiler connected to Honeywell Thermostat. It’s a simple thermostat to switch the central heating on and off. I do not have any timer installed currently (inbuilt or otherwise).
Just wondering how easy is to install the Hive thermostats with current boiler set up. Below is the Hive wiring diagram. If I am understanding it correctly, according to this dia both mains and heating on off wire connection goes into the Hive Reciever. How would the installtion for Hive work in this case?
Thank you.
Jag
Thank you.
Jag
