Hi all
Got a very old looking outside tap at our house which is not in use. A plumber is visiting soon to do a bathroom refit, and whilst here will remove the tap and cap it off. I asked whether this would cause a problem with a "dead leg" and he said no, but I want to check with you guys here please.
The tap is behind a fake door which is just there for aesthetics as it's bricked up behind. I guess the tap itself is a dead leg isn't it? If so, shortening it can only be a good thing, but is it enough?
The last photo shows the water meter cover in the ground. So the tap isn't far away from that. There are two stop cocks in the house, neither of which are near the meter or outside tap. One is around 8 metres to the left and the other about 10 metres to the right (both in the middle of the house, not on the outside wall you're looking at). So I've no idea at all where or how the outside tap is connected, if/where it is tee'd off from, etc. Also, a you can see there is a slab of old concrete in front of the door. Plus the oil pipe is underground somewhere between the meter and tap, which would make digging a little more of a pain.
Goes without saying that the cheaper and easier option is preferable, but at the end of the day I want it to be right and most importantly I want my drinking water to be safe.
To dig or not to dig (cap and forget)... That is the question?
Many thanks for any help
