KX15DT Sensor activated by movement through window
30 Jun 2018
Hi all
I have a Pyronix KX15DT sensor that is opposite a South facing bay window at the front of our property. I believe it is causing the alarm to sound when it's picking up movement outside (ie through the window). I think this because I set the alarm off when I drove onto the driveway.
Also the alarm triggered twice from the same front room whilst we were away a couple of weeks ago.
Is it possible to get triggered through glass?
If so, is there anything I can do to prevent more false triggers?
Many thanks as always.
T
Did you correctly set up the microwave range or just fit it out of the box ? As the microwave can leak out of glass ….
I think the latter - but it was 2-3 years ago.
I have documented what I did, but trying to find it at the moment....
OK just founf the instructions and I didn't touch the microwave potentiometer so supect it is set to 15M which would go outside onto the drive way :-)
I will try turning it down.
Thank you Sparky!
Normal thing is look at microwave light ( amber ?) walk outside near the glass …..does it come on ? If so reduce range and retest …
OK, so I turned the microwave potentiometer right down (fully anti-clockwise) and wandered outside. I still trigger the green led through the window but not the blue led.
Not sure what led colours mean, but I have seen blue, green and amber at different times on this sensor.
Is the aim to stop the blue led lighting when Im outside?
Having re-read your note above, the aim is to stop the microwave leaking through the window.
I think the microwave light is the blue led as when I turn the microwave pot right down that blue LED doesn't come on.
However green LED does still come on.
So I'm now going to tune it so the blue one only comes on when I'm in the room and not worry about the green one.
Is that right?
Yes you are correct Sally2000, I read that too, but sometimes its the only option...
Is that right?
no orange light is the microwave ……blue is alarm …..green is the IR ….If the green light is on all the time even when you are out of the room then it’s faulty …
Sorry to add to the confusion. What I meant to say was the green light only comes on when I move about close to the window (outside), it’s not on permanently.
