I bought a new build flat this year and there are very visible joint lines in the drywall in all rooms of the walls and ceilings. Is this normal??
I've had the walls checked and they are all within the 5mm tolerance as none are mis-aligned and apparently are not required to be skimmed.
Is there something else that should have been done to prevent these visible lines?
