Yes.
These are high quality screws but unless you are prepared to drill a clearance hole in the boards for every screw you will get 'Ramp Up' ( where the threaded screw lifts the board a little before it gets start in the joists and because it's Fully Threaded it will NOT pull the boards tight to the joists) which will eventually leads to a noisy floor when walked on.
As are ReisserSpax are a good brand but expensive.
If you press down hard as you drive the screws (and if needs be put your boot on the floor next to the driver) and you have a decent quality screw which will cut its' own countersink as the head enters the wood (e.g. Reissers, etc) then that doesn't often happen - and when it does you reverse the screw out and redrive it in a new place, not the original hole. It also helps if you are using a fast impact driver (i.e. 3000 rpm or fsster as opposed to a 1200rpm drill as this job is hard on kit). With collated screws, where you can bear down hard on the driver, the job is quite quick with only the occasional 'misfire', but then flooring screws are often square drive as well which is less likely to cam out than PozidrivThese are high quality screws but unless you are prepared to drill a clearance hole in the boards for every screw you will get 'Ramp Up' (where the threaded screw lifts the board a little before it gets start in the joists and because it's Fully Threaded it will NOT pull the boards tight to the joists) which will eventually leads to a noisy floor when walked on.
