I've bought this tap from Aldi and had planned to install it in our utility room for washing veg, walking boots etc. The online details I've copied below say that it's not suitable for "low pressure systems". We have a open vented hot water cylinder, the F&E tank is in the loft and the utility room is on the ground floor, such that the water level in the F&E tank is 5 metres above the level of the existing tap outlet. It provides a pretty good hot water flow rate, although obviously the pressure is not as high as the mains fed supply to the cold tap next to it.
So my question is, will this tap work for me? Or would it only work with a combi boiler? I assume by it not being suitable for "electric storage heaters" they are referring to a stored hot water supply, which would also rule out an unvented hot water cylinder, but can't imagine why.
