you will have to follow them then and find out where they meet, do you have solid floors ?
yes possibly, cant see why not, no need to take off a whole section, just enough to get into the pipes , then new part board and tape then decorateNo, wodden floors upstairs but the bathroom has a new vinyl floor just fitted too and I'd perfer not to lift it, can the work be done from the bedroom side and take off a section of plasterboard on that same parting wall to get at the pipes?
then no everything can be done from the bedroom wall no need to access the floorMy pipes are coming through the stud wall into the rad
1. Before doing anything, check if the front and back of the radiator are identical, or whether the back has fixing points welded to it.
2. If identical, you could turn the radiator side for side then fasten it back, ending up with the pipe in the correct configuration.
3. If not identical, see if it is possible to rotate it 180 degrees in the same plane. You'd need to check with the manufacturer whether or not this would be OK, or whether you'd end up with the same problem.
Not all are the same , some on the left some on the right, down to manu, he should have read the installation instructions, some dont need a baffleSo, those tall rads all have flow on the left, why is that?
No problem mate ask away, the problem with rads in a bathroom is the fairer sex insist on covering them with towels so they struggle to heat the room , no matter how many times you explain this to her she will do itOK, thanks, your right, he should haveSo, would you say, its a powerful enough rad, if it had of been connected the right way round?
No more Qs from meThanks a lot.
