- Joined
- 22 Jan 2007
- Messages
- 24,296
- Reaction score
- 3,625
- Country
No it doesn't
Yes it does, it is a feed and expansion cistern, the cistern takes up water expansion through the feed.
No it doesn't
With the pump off the water level in the F&E cistern and vent pipe will be same, therefore having the same pressure. It doesn't matter how far apart they are.
Opinions differ.....
Until the customer goes, oooo, what's this for, lets close it ....Keep the valve open, then it's an open vent system.
Well if I actually needed a plumber, something that I have actually been for more years than I'd like to recall, it certainly wouldn't be you I'd be calling, you're downright dangerous ... and I'm am now going to ignore anything you have to say on this subject as again you really don't know what you are talking about.No it doesn't. A vent is for venting, a feed is for feeding. If your feed is venting, I suggest you call a plumber.
No it doesn't.
Excessive expansion (aka venting) goes in EXPANSION pipe (aka vent pipe).
OK, had enough now, you really don't know what you are talking about ....
@wardr77, unfortunately your post has been somewhat highjacked by erroneous and ill informed advice, as always in an open forum it is up to you what advice you listen to and what advice you don't.
Unless I've misunderstood all throughout my apprenticeship and the last 40 years installing.
Ok I can do that, how long can i safely leave the x400 in the system for? Thanks
