Vokera Linea 28 having constant ignition banging noice
19 Dec 2021
Hi All, I am newly passed gas engineer,
Boiler continue banging burner chamber and get full flame in the burner and after 7/8 sec flame goes off, This is going goes on, it produce lukewarm hot water, rads are getting slowly hotter. Pressure gauge is sitting 2.0bar
please help me diagnose this
Apologies, didn't really take stock of the title, is it banging as it lights (explosive ignition) or once its ran for a few secs it then starts to bang/thump?
What is your gas safe number else ask in combustion chamber. Carry out FGA on inlet air hint hint
My gas safe number is 007.
There are different kinds of banging. Record the banging with phone and upload to youtube. Then no guess work that way.
Ignition thump is caused by over-pressure from the gas feed.
Mechanical banging is caused by emergency water valve closing. This is from insufficient or no water flow.
Yes, ha ha I didn’t right words, apologies
Look at the flame and report back. Horizontal or vertical flue. As said earlier flue gas analysis on the inlet side of flue would aid diagnosis.
Inlet and burner pressure also needs checked
I highly doubt that, and 007 is based in Aberdeen.
This is correct. I am currently down in London GCHQ for official business. Whenever there is a need at the Gas Central Heating Questioners forum, there I am.
Yes it has horizontal flue, i will do analyse in flue inlet, flame i see is blue. I will check the pressures in both point inlet and p2
