- Joined
- 17 May 2012
- Messages
- 11,423
- Reaction score
- 1,022
- Country
I have some washers to help hold insulation boards in place, but the 6mm x 120mm screws (Wickes multi purpose) I bought are too bit - they go in but the screw head is too large.
I think I need something like a 5mm 120mm screw, but not finding many options. Can anybody recommend one?
Although, maybe a better option is to get something bigger, like these Load Spreading 60mm Polypropylene washers - I assume the screw head will sink a little into the insulation.
It is for 50mm Kingspan + 10mm STS tile backer board, (plus about 10mm gap/adhesive foam) to go into brick. Then it will be tiled, so obviously needs to be pretty flat, maybe flatter than if rendering (eg on external insulation)
I am wondering if I can just use a 4.8 x 120mm drywall screw - but will these securely fit in a wall plug?
These don't work:
These don't work:
