Good, halfway there! last task is to make the unused blue wire a neutral.
What could possibly go wrongGood, halfway there! last task is to make the unused blue wire a neutral.![]()
Now you've confused me again, isn't the blue sleeve indicative of it already being neutral?Good, halfway there! last task is to make the unused blue wire a neutral.![]()
But you might be lucky, get the multimeter out again and measure between brown and blue. If you get 230V it's connected.2. Find the other end of the blue wire and attach it to a neutral associated with the boilers electrical supply.
In a perfect world the electrical connections should not be where an electrical inspector can't inspect them, or he would need to award a code FI which is a fail with an EICR, it is not a perfect world, and it seems some manufacturers do put electrical connections in sealed compartments, but one would hope at least they would affix a large sticker to warn electrical inspectors not to remove.post about a gas safe engineer
there was an attempt to clean up the way electrics were installed with Part P
In this case no, Part P was introduced mainly due to kitchen fitters who would ignore the rule book, but it removed the need to show some one was working in the home, in the main the electricity at work act and others covered the home as some one at some time was working in the home. But Part P made it easier to show a law had been broken.If you mean notification, it has nothing to do with Part P.
In this case no
