- Joined
- 27 Jan 2008
- Messages
- 29,428
- Reaction score
- 3,615
- Location
- Country
Ohms law 47Ω 20A = 940 volt. Clearly some error.
In the main we have an earth rod only good enough to ensure enough current to safely operate a RCD. Where earth are better then some method is used to limit current, one does get neutral earthing resistors, but although worked on a site with a huge resistor I am not really up to speed on when they are fitted or why.
However I have had impossible readings using an AVO auto electricians multimeter due to RF in the area, it was so crazy 25 amp for a little transceiver with a 5 amp fuse which did not rupture it was clearly the meter up the creak.
Since the readings don't add up, I would suspect some measurement errors.
