Anyone remember that green engine oil - Duckhams 20W50?
I still have some in my old dad's red oil can
one of these, obv.
After research, another possibility is they let the gearbox hang on the input shaft which has bent it. Is this a possibility? How would you check if shaft is bent?
As Harry has suggested dial gauge and rotate shaft, does anyone know if this is possible withou fully removing box? Or does it need to come out completely?
A bent input shaft would show up by mounting a dti on the gearbox casing and rotating the output shaft by hand with the box in gear.Ideally you’d need to remove the shaft from the box, and spin it in a lathe with a dial indicator rubbing on it.....one hell of an undertaking!
I think you’ll see the issue when the box is off - the leak will have washed the area clean.
John![]()
