Most likely external - the fuse will break when there is a fault current over 1A (plus a bit).Can 1A produce that much of an explosive power, or is the breakage expected from an external trauma?
If that fault current was say, over 35A, with a glass fuse (unlikely), then arcing across the fuse may sustain that fault current.
In the case of the ceramic fuse, it would still protect the circuit up to a fault current of around 100A.
