Arrow would be another, more specialist though than run of the mill though and are classed as a WRAS specialist. They specialise in RPZ/flow limiting as well as service & ISO valves amongst others. They are one of the few that actually create valves where the inner and spindle seals are serviceable.
Outstanding. Madrab - did you happen to come across arrows education section.
They have numerous guides that cover both water regs and solutions.
This is a pdf they have specifically on isolation valves, their construction, specifications and their place in water regs. It even speaks about their use as replacements to traditional stop cocks plus the issue of check/non-return valves.
It is a little old & i'f inagine it may be due an update - but it is quite in depth and a rich resource on the topic at hand:
credit: This is a pdf that is produced by and provided by arrowvalves. They have a rich education section with multiple pdfs. The copyright & work belong to them. I have provided this link in good faith to further this discussion & exploration.
Invariably it's down to the manufacturing quality and tolerances of the stem seals and the teflon (PTFE) socket seals that the ball sits in and the construction quality.
As mentioned, they are very good for WRAS stuff when it comes to following the regs and as far as critical backflow and actual water control is concerned. It's more relative when it comes to commercial stuff.
