Wood Oil
11 Nov 2020
Middle Earth
I've sanded down the front of three drawers ready for varnishing but i'd like to protect the bare wood panels on the back and sides without resorting to varnish.
Can anyone recommend a good wood oil that'll protect the bare wood and allow the drawers to slide smoothly without sticking?
Some sort of colour matched wax
Blup
Blup
I have a natural beeswax; 'Lord Sheraton', but wondered if there was something that could soak into the bare wood for a longer lasting protection.
Danish oil, but ensure dry before fitting, you could also add wax on top.
If your drawers are on wooden slides (e.g. planted-on slides or grooves in the sides which locate on wooden strips in the carcase), or they just slide on the bottoms of the drawer sides, then oil doesn't work (it tends to stick). Wax does. Which is why it's been used for a very long time as a lubricant
Yes, the drawers slide on top of wood supports, so i guess wax is the way to go.
I just wanted to see if a better alternative was available.
Thanks.:)
Traditionally drawers were left unfinished (other than the fronts, which would be a show wood and stained and polished) with only a bit of wax on the runners. The reason was that (French) polish can taint natural materials with it's odour, whilst some non-polymerised oil finishes (e.g. walnut oil, oils containing raw linseed oil, etc) can turn slightly rancid in warm weather and can also sweat back into fibres such as cotton and wool (which is partly why your granny always used to line drawers with wallpaper roll ends, rear side uppermost). Wax can do this, too, if usewd to cot the insides of the drawers. Modern 2-pack catyalysed finishes overcome this, but leave the wood less able to absorb or lose moisture - so condensation inside a drawer (maybe because a dried item was put away too damp) is more likely to stay trapped there with slightly increased risk of mildew forming. This shouldn't happen in a modern centrally heated house with the RH is very low, but can still happen in older buildings with solid walls and wood stove heating, for example
