No hot water - Ideal Logic Combi 30 Boiler
9 Mar 2022
Good afternoon,
A few days ago I topped up the pressure on the boiler and bled the radiators.
The central heating is working perfectly fine but now I have no hot water coming through the taps.
There are no error messages coming up on the boiler.
Any help would be greatly appreciated.
Purely a guess... Does this boiler have an isolator for the hot water (usually underneath), that you've turned?
It most likely does but I'm pretty sure I didn't touch anything else other than the filling loop
you have not turned the tap back to correct position ,left hand one
Had this call out before. I agree with the isolation valve under boiler has been moved in error. Easy to do. Had one the other day ideal logic, customer topped up pressure and had isolated the CH pipe at some point, probably at the end and had error codes coming up after, they thought it must be a boiler fault. Easy job for me and a lesson about what's what underneath boiler for customer.
EP3
