    Dismiss Notice
ideal logic 30 no hot water
Discussion in 'Plumbing and Central Heating' started by Steve2413, 19 Jun 2015.
  1. Steve2413
    Steve2413
    19 Jun 2015
    8
    Thanks Received:
    Country:
    Hi , central heating works fine , and occasionally hot water does , when a tap is turned on the red light on the flow sensor flashes ok indicating the flow turbine is working , sometimes front panel says hot water demand , most of the time it goes straight into pump overrun . I am edging towards divertor valve , any help and advice greatly appreciated . No error messages .
  2. Sponsored Links
  3. Snigie
    Snigie
    14 Dec 2013
    83
    Thanks Received:
    33
    Derbyshire
    Country:
    the flow sensor shouldn't flash, but you shouldn't really be inside the boiler, it forms part of the seal for the combustion chamber, which if not sealed correct and the boiler has a issue it can be dangerous.
  4. muggles
    muggles
    28 Oct 2005
    13,342
    Thanks Received:
    3,077
    Daventry
    Country:
    As above, the front casing of this boiler forms the room seal and as such it should only be removed by a Gas Safe Registered Engineer. Time to call someone in
  5. logic 30 plus?
  6. gigz
    gigz
    7 Oct 2006
    8,427
    Thanks Received:
    2,282
    Country:
    Same boiler as the 30 but scrolling display
  7. Sponsored Links
  8. xfr
    xfr
    12 Feb 2010
    135
    Thanks Received:
    12
    Northumberland
    Country:
    Is it not still under warranty??I had exactly the same problem in a rental property.They were out next day and replaced a part.
    sorry don't know which part,but was very impessed with ideal customer service..
  9. gigz
    gigz
    7 Oct 2006
    8,427
    Thanks Received:
    2,282
    Country:
    5 yr warrenty with the plus (if its been registered)
  10. bogstandard
    bogstandard
    7 Jan 2005
    94
    Thanks Received:
    Country:
    7 yr warrenty with the plus NOW!
  11. Steve2413
    Steve2413
    19 Jun 2015
    8
    Thanks Received:
    Country:
    It is the plus ,my neighbour is trying to fix it for me, he is gas safe but doesn't fault boilers , most of his work is landlord certificates , so we are just trying to find out what it is , by his own admission he doesnt know as the display doesnt show any error codes .
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
