may or may not be has the glass internal fuse blown ??
could be hidden, would expect it to be at the output to charge end but just a guessI couldn’t see anything that looked like a glass fuse inside on the board ![]()
you probably wont have to solder the actual fuse that is very unusual but have come across itThanks.. but to tell you the truth I’m not one for messing about soldering unfortunately.. if it was a straight swap out like a normal fuse then yes I’d do that.. but as said it’s easier and as cheap to buy another charger knowing its caput if I dare
