- Joined
- 5 Oct 2020
- Messages
- 140
- Reaction score
- 3
- Country
Hi All, can anybody please help me to solve this puzzle?
Replacing cooker hood.
Existing round flex connected to existing hood was only 2 core and had no earth.
New Hood is only class 1 (Bosch!) and requires an earth.
I have a 13amp Fused Spur above the cupboards (see picture) and this isolates the round flex/existing cooker hood.
The igniter on the gas hob still works when isolated.
I found a socket behind the cabinets below hob (which has a plug and flex running up to below hob and think this is for the igniter).
My plan was to cut the plug off end of hood flex and pull through on existing 2 core and terminate inside that fused spur above the cupboards.
Problem is its spur is flat 3 core t&e therefore it must run somewhere else, terminate there and then the existing 2 core runs from that to the hood?
Can't find that ANYWHERE and judging by the direction of the 2 core running in the wall it runs off towards that cabinet below the fused spur... Therefore I reckon it's behind that cabinet and dont really want to go taking the cabinets off the walls....
What's the best way of sorting this?
It's a timber framed house and has joists running parallel between the hood position and the fused spur, therefore I've got no chance of getting through to join new cable up there.
However I can get down the wall to behind the hob and could break the ring going into that socket, fit a fused spur in there, and run new 3 core round flex up the wall to the hood, and then connect the ring back up to the socket next door where I picked up from, but not sure cables can be run up the wall behind the hob and hood?
Please see below pictures.
Any help appreciated
