- Joined
- 20 Apr 2022
- Messages
- 4
- Reaction score
- 0
- Country
Hi all,
Had a search but couldn't quite find the answer to my question before posting.
I have an issue with a small utility area in terms of ventilation. There is a washing machine, condenser tumbler and a rail for hanging damp clothes.
Currently there is an old air brick only.
I know this isn't sufficient for dealing with the damp clothes and likely the tumble dryer.
My options are (as I see it) -
1 - buy a vented dryer and install a ducted vent
2 - Install an extractor (probably humidistat?)
3 - both of the above
Is both overkill? Dryer likely needs replaced anyway as the board is knackered on it.
If I'm installing an extractor fan, is it possible to go through the existing air brick by core cutting? It's an external cavity wall. I don't have a lot of space to work with due to obstructions on the external wall and the air brick is in the ideal spot.
There is a slight gap under the doors to the cupboard - would this be sufficient for allowing air flow into the cupboard if a fan was installed?
If the air brick needs to stay, is there a minimum distance a fan needs to be from it to allow adequate flow? Eg, above/below the air brick.
I appreciate that's a bit wordy! I've attached a couple of pics that might make it clear.
Thanks all
Thanks all
