I thought the bedding material was shingle (or pea gravel by another name)It's merely to provide protection to the pipe from punctures caused by jagged stones that might be in the back filled soil or the bedding material.
Yeah, wasn't that the OPs question?I thought the bedding material was shingle (or pea gravel by another name)
It most certainly was, but your answer was talking about jagged stones that might be in the bedding material that was suppose to protect the pipe from jagged stonesYeah, wasn't that the OPs question?
Why did they need the concrete surround?Pea shingle is also much easier to work with as the bed. Easy to level, and when the pipes are in easy to make adjustments to them. Having flexible joints allows for ground movement. With the old salt glazed and sand/cement joints they needed a concrete surround.
Because the joints were formed in sand/cement mortar, and any movement would damage the joints. The theory was that being completely surrounded by concrete would stop this happening to the pipe run even if the ground moved. You had to test the drains first and then again when creted. And then again when backfilled.Why did they need the concrete surround?
Me and my spaniel both agree that it saysIt most certainly was, but your answer was talking about jagged stones that might be in the bedding material that was suppose to protect the pipe from jagged stones
