Hi all,
About 7 years ago we filled/plastered a disused fireplace in our lounge to return it to just a flat plaster wall.
The chimney is external and an air brick was fitted to allow air to circulate along the external chimney (see photo).
The chimney is also capped with a paving slab (or similar) at the top and covered in wire mesh to prevent birds falling in (used to happen regularly!).
It's been good as gold, we've had no problems with sweating or damp patches on the lounge wall at all.
However, I'm pretty sure the lack of any insulation in the chimney means we lose a fair amount of heat through this part of the wall in the lounge and bedroom above, in winter. The air moving so freely through it presumably just sucks warmth off the interior walls.
I've measured this indoors with a thermometer in winter, and the parts of the wall with the external chimney on are a fair few degrees colder than the rest of the wall (which has cavity insulation).
My question is, is it ever possible to insulate a disused external chimney like this?
I know you "have to allow ventilation so that the air in it doesn't condense/cause sweating". But is this not because it's such a large empty void containing lots of air?
i.e. If it were filled with something like wall insulation (polystyrene beads or whatever), would that remove the need to keep it so well ventilated?
I'm just thinking about rising gas prices and trying to find places heat will be escaping that I can potentially do something about, before next winter?
I've seen the inflatable bags etc. that you can shove up a temporarily unused chimney but I wondered if there's some more permanent/better performing options to prevent heat loss from it (without causing damp in the lounge and bedroom)?
I know the other option would be to look at entirely removing the external chimney but I don't think my budget will stretch to that sadly!
Thanks,
Andy
Thanks,
Andy
