Does my house need a rewire?
23 Jun 2022
Germany
Hello, who do I ask to determine if a house needs a rewire? Can I just get a few local electricians out to check the electrics in the house and ask for their opinion? Or will an EICR tell me if the house needs a rewire?
I am moving in to a new property and given how invasive a rewire is, I would prefer to do one before we move in if it is required (or would be required in the next 10-20 years).
In the main if wired with PVC cable it may need work, but unlikely a complete rewire. The EICR should tell you, that's the whole idea of doing one, even mothers house built 1954 when I came to get it rewired to remove the rubber cable and get earths to the lights, the kitchen and wet room hardly needed touching as has be done previously.
1966 in the UK the rules clanged, and from that point we needed earths on lights, so wiring pre-1966 likely will need rewire due to lack of earth and rubber cables, after that date more likely some tidying up not complete rewire.
There has been batches of poor PVC cable, where you see a green grunge as plastersizer leaches out, that would need rewire. Or overload where ring finals have been broken, but this is reasonable rare.
How old is your “new” house.
I assume you had a survey. Did this say anything about the electrics?
Note: this answer assumes the house you are buying is in the UK
There are some installations where the need for a rewire or at least major remedial works is obvious from a quick visual inspection.
It would however be a brave electrician who said a property *doesn't* need a rewire based on just a quick visual inspection.
A competently executed EICR should enumerate the safety deficiencies the inspector has discovered in the electrical installation.
No inspection is perfect, even a competently executed EICR cannot be guaranteed to find every defect. The defects are coded by the inspector, there is industry guidance on coding but ultimately it's down to the inspector to assess the risk of any particular defect.
C1 - ‘Danger present’, this is issues that need to be addressed immediately. Things like exposed live conductors.
C2 - 'Potentially dangerous' this is mostly issues that are one step away from becoming dangerous. Exposed conductors with only basic insulation. problems with the earthing/bonding system, degraring insulation and so-on. Industry guidance also places lack of RCD protection in certain higher-risk scenarios and socket outlets too close to baths and showers in this category, though i'm sure some electricans would disagree with them..
C3 - 'Improvement recommended', lack of RCD protection in lower-risk scenarios, various nitpicks about labelling and so-on.
After an inspection you would then need to figure out which defects are going to be addressed and how. If you are renting out the property you are legally required to address C1 and C2 defects, if it's your own home you aren't legally required to address anything.
"needs a rewire" isn't nessacerally black and white. There are some properties that definitely need rewiring but there are others that could be remediated but it's questionable whether a rewire is the better option.
Broadly speaking there are a few reasons for rewiring.
1. Old rubber cable, old rubber can go hard and crumbly. It's insidious because it can work and test fine as long as it's not disturbed but then crack or even disintegrate when someone tries to work on it. For this reason trade organisations recommend that any interference with rubber wiring is kept to an absolute minimum until the property can be rewired.
2. Lack of earths on lighting circuits. The IEE wiring regs changed to require an earth on lighting in 1966, though whether everyone immediately started following them is another matter. Doing any kind of modification work on circuits without an earth can be very awkward.
3. Defective cable, plastic insulation generally lasts a bloody long time (long enough that we don't really know how long it will last because it hasn't been in use long enough) but not all cable is created equal and there have been some cables where the plasticiser leeches out making a bloody mess and potentially making the cable brittle.
4. Damaged cable, for example if there has been a large-scale rodent infestation or a fire or something similar.
5. Horrible bodges, afaict most installations were initially installed in a competent manner. IIRC many electricity boards would insist on an inspection before they would connect a house, but over the years what people want out of their electrical installations has changed and people have modified their installations to suit. Sometimes competently, sometimes not so competently.
6. The installation simply isn't what you want. There comes a point when you look at the list of things you want to change about an installation and decide it would be easier to start again.
Are you in Germany?
Yes @JohnD, I am in Germany, however I was hoping most advice from the UK (where I am from) would also apply in Germany. I had a EICR on a property in the UK in the past, however I have found there isn't an equivalent available in Germany.
It's from 1950, but I haven't yet done a visual inspection of the electrics. e.g. during the viewing I didn't even check the consumer box, light switches etc. Rookie mistake as an inexperienced buyer.
People in Germany generally don't do surveys when buying a house. It's astounding.
Thanks @plugwash for the information.
I think I need to find some German DIY forums...
A 1950 house?
I would assume, without looking at it, that either it has already had a comprehensive rewire
Or it needs one.
