- Joined
- 12 Jun 2022
- Messages
- 60
- Reaction score
- 1
- Country
Cherrs for your reply...ABV - Auto Bypass Valve. When all the CH system valves close, it allows for min flow through the boiler on pump overrun.
If you're in a flat without a drain off then usually it would be drain each individual rad and then find the lowet point on the pipework and drain the rest at that point.
If they used best practice when it was installed then there would normally be a drain tee'd into the system pipework usually at the lowest point of the pipework under the floor at the boiler, with a pipe punched through the wall. Not a lot of installers seem to do that these days though.
Not at window ledge height nope, that's just be for the release valve.I got the drain pipe outside does that definitely mean it's attached
Does the pipework and the valve get hot when the CH system is on? Chances are it's still connected to the main CH pipeworkThe auto valve seems to have been left in from the old system or would they have connected it to the combi
The TRV's react and closes the valve off once the air temp reaches the setting on the valve head, they're basic on and off switches,Oh yeah I think they all have trv thermostatic values aka can adjust them /amount of water passing though I guess thats how it works with regulating the temperature?
Honestly ... It's an ABV. It needs to be set properly to work correctly, you need someone that knows CH systems to check it. What combi boiler do you have - Make and Model.Isn't it just the old temperature control for the old hot cylinder?
