Low mains water flow stumped!
No, sometime older connecting couplers can silt up,or corrode, that can then restrict the flow. It seems the static pressure is ok but dynamic is poor.
A 1 bar dynamic drop per outlet is quite signinficant but again that could be down to a restriction somewhere. You need to know from the transporter what the dynamic readings (pressure and flow) are on the main, that gives you the starting point. The mains can alost always be considered to be dynamic as you can just about guarantee that multiple users are actively using the mains at any given time. If the readings are signig9fcantly dirfferent at your mains tap then it's almost certain that your mains supply pipe is to blame.
Where are you located? Are you rural or on the outskirts of a town?
Connecting couplers for what though? Old lead to new plastic ?
I am in the middle of a town but at a high elevation relative to the surrounding area.
depends what's under the ground as part of the supply pipe. we're not saying that's what it is, just what it could be.
Have you asked the neighbours as to what their supplies are like, can you ask a neighbour to do the test on theirs too and see if there's a correlation?
Had the water board round and they have 3 bar of static pressure at the meter (same as what i've got internally) and over 25L flow rate. They also measured my garden tap at around 7LPM which is the same figure I came to.
Also lifted some floorboards to find the black poly pipe does exit the property as I was half expecting to find galvanised steel coming into the house and then poly connected up to that.
As it exits the house, I thought it seems unlikely that it isn't black poly all the way to the meter?
Options:
1) Start digging up garden in case it does transition to lead/steel or on the off chance I find a random stopcock or coupler.
2) Get a new 25mm mdpe supply moled in.
3) ??
The water board said poly is coming to the end of its life and lots are leaking now so seems like it's best to not b*gger around with it and go with option 2?
OK, as that's measured at the mains, it will always be dynamic as the mains is always being used by lots of people all the time so that's a result
Now it's all about increasing the flow, as suggested, that needs a fatter pipe.
If option 2 is a goer then that would be the best future proofed solution. Depending on what you want the mains to feed inside the property then even consider 32mm.
Once that's roughly measured/estimated, the attachment might be a handy aid to navigation if pipe ID is known, the static head is known @ 3.0bar.
Roughly what distance is it from the meter to the house stopcock?
Around 20m,
I used one of those calculators before the flow should be about 20LPM so somewhere there must be a large restriction.
When I moved in the stop tap by the meter had moved so it was pushed right up against the side of the pit so the tap couldn't be rotated, the water board came out and replaced it with a 1/4 turn plastic jobbie. My guess is whatever caused the stop tap to move is also crushing my pipe.
Around 20m,
I get 14.4LPM from a 3/4" bath tap at a dP of 2.65bar (3.6/0.95) measured with PG downstairs through 20M of 21mm, 11.5MM ID Hydrodare HDPE (50 year old) piping, (theoretically, per friction loss table, should only be 1.2bar), if I reduce the flowrate to your 7.75LPM I get a dP of 0.77bar, so seems something up with your piping all right if it has the same 11.5mm ID, so running a new pipe in 32MM or whatever seems the way to go.
If you have low flow just now, then that is down to the supply pipe you currently have to your property, regardless of what length/dimension/restrictions/etc there may be.
Putting in a new run of 25/32mm MDPE will maximise that flow and get you close to what the mains is currently running at out at the meter, it doesn't need to be complicated.
Had a new main moled in. They said there was a section of galvanised and copper just before the water meter. As you'd expect, issues all sorted now, can flush the toilet whilst having a shower and not even notice.
Eureka! :rolleyes::ROFLMAO:(y)
