No, sometime older connecting couplers can silt up,or corrode, that can then restrict the flow. It seems the static pressure is ok but dynamic is poor.
A 1 bar dynamic drop per outlet is quite signinficant but again that could be down to a restriction somewhere. You need to know from the transporter what the dynamic readings (pressure and flow) are on the main, that gives you the starting point. The mains can alost always be considered to be dynamic as you can just about guarantee that multiple users are actively using the mains at any given time. If the readings are signig9fcantly dirfferent at your mains tap then it's almost certain that your mains supply pipe is to blame.
Where are you located? Are you rural or on the outskirts of a town?
