What toilet seat is this?
22 Aug 2019
Hi. Im trying to find a soft close, D shaped, quick release toilet seat (34 x 43cm). It has to fix onto the existing quick release mechanism because I cant get at the underside of the toilet. Heres a photo:
I cant seem to find a replacement! The ebay seller I bought the toilet from is nowehere to be found, and other suppliers have similar quick release seat, but not the same.
Any help would be appreciated! Thanks
As said, remove what you have and start afresh with a new top mounted seat and fixings. All done without removing the pan.
....and sorry, not helpful, but I have to say... thank you for your photo of a clean toilet! :)
You wouldn't believe some of the images posted on here, for similar issues! :sick:
Can I do it without removing the pan? It seems to me that if I unscrew the 2 screws, the nuts underneath will just fall off. I wont be able to get underneath the pan to hold the nuts to tighten them again. Im probably wrong!
Yes, you should have seen it before I cleaned it!! :sick: (its not my toilet I hasten to add!!)
Hmm, I cant find a toilet seat which is exactly same size as mine. Does it matter?
Mine is 34 x 43cm; whereas the ones Im finding on ebay are usually 37 x 46cm. Does it matter much or should I try and get one exactly same size?
