Sham pain
So you are suggesting all the CH installers in Europe are not in their right mind?
StetWill you please stop your irrelevant bleating-on about other countries electric rules/regulations/systems.
This forum is:
and whatever happens in another country is totally irrelevant, even to the point this site has a special place for any such comments:
I don't care a jott what their regs/rules/laws are when I'm working on systems in UK,
Sure. but I only mentioned A-V equipment because you brought it (a TV) into the discussion when I injudiciously used the word "component" to refer to the component parts (e.g. pump, valves, stats etc.)of a CH system ! ....With respect I don't think it's possible to compare an AV system comprising multiple interconnectable modular products with a heating system designed as wirable (actually stripping and terminating multicore cables) components. Equally I don't see how one can compare a motorised valve with a video recorder.
Exactly, and that is obviously NOT what I meant when I used the word 'component'.When I mention TV components I'm referring to the mains transformer, bridge rectifier, smooting capacitor, IC's, resistors, inductors etc and I'm quite sure nobody would consider those parts require individual protection.
I don't think anyone is arguing that. If there are 0.5mm² wires connecting parts of the system, then they require appropriate protection.I don't know why some persist in argueing that CH systems don't require a fuse, 3A or otherwise. Surely nobody in their right mind would consider connecting such a system with its 0.5mm² wires directly into a 32A, or even 16A, circuit without a smaller OCPD.
Quite, but at least in the UK, over-current devices within an electrical installation are there solely to protect the cables of the fixed wiring of the installation, not things connected to it - and if equipment connected to the installation requires 'better' protection than is required to protect the cables of the fixed installation, that should be provided within the equipment.As we regularly see quoted on here 'The fuse is only to protect the cable'.
Ones I have seen have a Schuko plug plugged into a 16 amp circuit (in a bathroom).Sure. but I only mentioned A-V equipment because you brought it (a TV) into the discussion when I injudiciously used the word "component" to refer to the component parts (e.g. pump, valves, stats etc.)of a CH system ! ....
As has been pointed out/asked, what do you think the situation is (e.g. in relation to a CH system) in most non-UK countries which do not have fused plugs or FCUs? Are boilers and other parts of CH systems in those countries manufactured (and connected together) differently, so as not involve 0.5mm² conductors?
Quite (although, as Sunray has pointed out, a 16A socket does not necessarily mean that the circuit has a 16A OPD) - so, as I asked, if it IS a "16A circuit", are such systems devoid of the 0.,5mm² conductors that concern Sunray (and/or are any such conductors appropriately protected within the equipment concerned)?Ones I have seen have a Schuko plug plugged into a 16 amp circuit (in a bathroom).
As I have already pointed out anything outside of the UK has absolutely nothing whatsoever to do with this forum and I wish other menbers would stop bleating on about it.As has been pointed out/asked, what do you think the situation is (e.g. in relation to a CH system) in most non-UK countries which do not have fused plugs or FCUs? Are boilers and other parts of CH systems in those countries manufactured (and connected together) differently, so as not involve 0.5mm² conductors?
Never knowingly seen a foreign boiler circuit protected with a 16A OCPD, however I have seen a number, and installed some, 16A sockets for boilers using lower rated OCPD. see #56Ones I have seen have a Schuko plug plugged into a 16 amp circuit (in a bathroom).
It's not quite as irrelevant as you suggest, given that this whole discussion arose because it was suggested that the requirements of MIs for boilers in the UK were such as they are because of a desire to ...As I have already pointed out anything outside of the UK has absolutely nothing whatsoever to do with this forum and I wish other menbers would stop bleating on about it.
.... make the manuals more generic (less country specific licalisation).
That's a valid point - but my eperience of non-UK electrical installations is so limited that I have no idea how correct it is.However in my limited experience of working in foreign countries I've found circuits dedicated to an application are usually (but I'll stress my experience is limited) protected with a suitably sized OCPD. regardless of the method of final connexion.
That's simple, I want to know when you stop your irrelevant bleating-on about other countries electric rules/regulations/systems which have absolutely no bearing on any points raised in this thread.Sunday. Good. I’m glad you agree with me. One wonders why you posted 56 then!
In my experience they usually fit a 3/4/5A fuse/MCB in their fusebox/CU for the dedicated circuit.I'm not so sure about "less country-specific localisation".
A problem with boilers (and a good few other things) is the requirement in MIs for ...
(from the Worcester MI posted by eric, but very common).
My understanding is that not only do very few countries outside of the UK have fused plugs, but nor do they really have any equivalent of an FCU (other than large 'switch-fuses', for which 3A fuses may well not be available). If they intend that their instructions be 'more generic' and 'less country-specific', how is a user outside of the UK meant to implement this requirement for an external 3A fuse, I wonder?
The point is that the physics is exactly the same so it can be deduced that if the UK does something no one else does then it probably is not necessary.As I have already pointed out anything outside of the UK has absolutely nothing whatsoever to do with this forum and I wish other menbers would stop bleating on about it.
I have one. It is just plugged in to the socket circuit.Never knowingly seen a foreign boiler circuit protected with a 16A OCPD,
Did that include lower (than 16A) rated cable being installed?however I have seen a number, and installed some, 16A sockets for boilers using lower rated OCPD. see #56
It's still irrelevant when discussing installations in UKThe point is that the physics is exactly the same so it can be deduced that if the UK does something no one else does then it probably is not necessary.
Is that relevant?Do not forget that plug fuses and hence fuses in FCUs only came about because of the invention of the Uk ring final circuit.
Thank you for the informationI have one. It is just plugged in to the socket circuit.
It was the first fixed cable, designed under the relevant regulations of the country, their round version of T&E, from memory I suspect 1.5mm². However I know not of their derating factors for buried direct.Did that include lower (than 16A) rated cable being installed?
No it isn't; not when discussing if things are electrically necessary.It's still irrelevant when discussing installations in UK
Yes, without the ring you would not have them.Is that relevant?
Ok.Thank you for the information
A good point. Why would the derating factor be any different between UK and European masonry?It was the first fixed cable, designed under the relevant regulations of the country, their round version of T&E, from memory I suspect 1.5mm². However I know not of their derating factors for buried direct.
