As I said, my experience of such things is not far from zero, so I have to take your word for that.In my experience they usually fit a 3/4/5A fuse/MCB in their fusebox/CU for the dedicated circuit.
Like EFLI, I disagree. If something is considered electrically acceptable in one country, then it leads one to at least question why it should not also be considered acceptable in another. Electricity, and electrical safety considerations, do not understand political boundaries.It's still irrelevant when discussing installations in UK
Excuse me but have I missed something? Is it not electrically necessary by UK regs to provide an OCPD for a thin cable? Physics aside the rules happen to be different in different countries. God forbid the results if a UK vehicle were to be driven on the left...No it isn't; not when discussing if things are electrically necessary.
But so what. We have them! the origin is irrelevant and they are an excellent way to provide the OCPD required for safely completing the job according to UK regs.Yes, without the ring you would not have them.
I have no idea if it is or isn't different or if different rules are applied.A good point. Why would the derating factor be any different between UK and European masonry?
Indeed it is - and, hopefully, the same is true in terms of the regs of any other (sensible) country.Excuse me but have I missed something? Is it not electrically necessary by UK regs to provide an OCPD for a thin cable?
Yes, but if the rules are electrically satisfactory/adequate in one country, then it can be suspected that any 'more demanding' rules in any other country may well be (electrically-speaking) 'unnecessarily demanding'.Physics aside the rules happen to be different in different countries.
However different countries do have differing levels of safety awareness and rules, accordingly I'd not be surprised if their electrical rules follow suit.Indeed it is - and, hopefully, the same is true in terms of the regs of any other (sensible) country.
Yes, of course but the goalposts have moved from the original "a 3A fuse must be used for a boiler" (or extractor fan).Excuse me but have I missed something? Is it not electrically necessary by UK regs to provide an OCPD for a thin cable?
Obviously - but would you argue that driving on the left in the UK is safer than on the right elsewhere?Physics aside the rules happen to be different in different countries. God forbid the results if a UK vehicle were to be driven on the left of a German Autobahn.
Again, that is the point; rules do not alter physics. I don't think it takes much working out.I have no idea if it is or isn't different or if different rules are applied.
Yes, but we are talking about EU countries, and I would not expect them to have appreciably 'more lax' safety awareness than does the UK, would you?However different countries do have differing levels of safety awareness and rules, accordingly I'd not be surprised if their electrical rules follow suit. ... One only has to look at the plethora of youtube videos to see ....
Whether any country has better or worse regs than us is totally irrelevant when discussing the wiring regs pertinent to a particular country. Just as most that has proceeded.Yes, but we are talking about EU countries, and I would not expect them to have appreciably 'more lax' safety awareness than does the UK, would you?
After all, for example, we are always being reminded that Germany has for a long time (perhaps for ever) not regarded Type AC RCDs as 'safe enough', whereas they have been the norm in the UK for decades.
I thought the whole discussion is about UK wiring regs. It wasn't me whos raised 0.5mm² wiringYes, of course but the goalposts have moved from the original "a 3A fuse must be used for a boiler" (or extractor fan).
Did I say it was or wasn't safer?Obviously - but would you argue that driving on the left in the UK is safer than on the right elsewhere?
Maybe not but I still don't know how or if derating factors vary between UK and overseas.Again, that is the point; rules do not alter physics. I don't think it takes much working out.
... and, although not explicitly stated, it's pretty obvious that the discussion about 'other countries has related to the EU, hasn't it?I missed the bit where this discussion is restricted to EU however my working experience is.
As has been said, it is relevant to look at regs in other countries when discussing whether people feel that those in the UK are 'OK', 'not safe enough' or 'unnecessarily demanding'.Whether any country has better or worse regs than us is totally irrelevant when discussing the wiring regs pertinent to a particular country. Just as most that has proceeded.
I didn't mean to send the conversation down that rabbit holeHowever, I would remind you again that this whole discussion started because Simon suggested that the MIs for boilers sold in the UK might be 'as they are' in order that they would also be applicable in other countries - which makes the question of other countries regs very relevant.
I realise that you didn't, but what you wrote seems to have unwittingly and unintentionally 'touched some nerves'I didn't mean to send the conversation down that rabbit hole![]()
I still don't see anything obvious about it, in fact I see just the opposite which is why I mentioned 2 different continents.... and, although not explicitly stated, it's pretty obvious that the discussion about 'other countries has related to the EU, hasn't it?
As you have now expanded the specifics of the cable size, the specific point I (and others) have mentioned is in the UK that is catered for in our regs. Others seem to be saying the cable size seems to be ignored in other countries.In terms of specifics, I doubt that any (sensible0 country's regs would say that it was acceptable to have a 0.5mm² cable protected by an OPD with a rating of 13A or above. However, nor would I really expect that any country's regs would require an item of equipment (which itself {and the cable feeding it}} did not require such an external OPD) be protected by a 3A OPD 'just in case' someone connected a 0.5mm² conductor to it.
Kind Regards, John.
If the disconnect imes and adibatic pass for short-circuits and the load is deemed unlikely to cause an overload (or there is downstream overcurrent protection) then why not?In terms of specifics, I doubt that any (sensible0 country's regs would say that it was acceptable to have a 0.5mm² cable protected by an OPD with a rating of 13A or above.
I suppose I asked for that, by mentioning only the first two of those considerations and not qualifying what I wrote by "when overload protection is required" - since, as you imply, at least in terms of UK regs, there are situations in which such protection may be omittedIf the disconnect imes and adibatic pass for short-circuits and the load is deemed unlikely to cause an overload (or there is downstream overcurrent protection) then why not?
