Has anyone had a problem with Dow 785+ grey silicone not curing?
My tube was only opened in April, doesn't expire till next year & has been stored correctly (cling film over the opening then nozzle screwed on).
I have a tiny bit of silicone on vertical line in shower that's coming away from the wall so rather than remove it all & redo it I was trying to patch it by putting new silicone over it.
I tested the silicone beforehand by putting a small bead on a piece of cardboard & although it took a good few hours it did cure.
I put a thin smear of it on the bit to be patched & after 24 hours it still hadn't cured (still tacky) even though it's a lot less thick than the test piece I did so I've just scraped it off.
Can't understand why as the tube doesn't seem to have gone off.
Anyone have any ideas?
