My Biasi RIVA COMPACT HE MK2 M96A.24SM suddenly has a fault.
I have DHW but no central heating. Boiler fires up on the taps but not on CH.
I have bled my radiators, the water pressure is at 1 bar, slightly high I know and I've left the CH on for 2 hours but still won't come on. Thermostat is fine. Fuses are fine. I usually turn the central heating on via the thermostat when I need it.
Normally when I turn on the hot water tap I can hear a thud which is I believe is the divertor valve switching position via the actuator, not now. After disconnecting the actuator I can see that the pin is always in the forward/out position. I am able to manually push the diverter valve in and out.
When I turn on the boiler via the mains switch I can sometimes hear the actuator motor spinning but not always and some clicks!
Hot water runs into the radiator pipes as long as the hot water taps are open!
Could it be the primary circuit pressure switch? Someone elsewhere on the site had a similar problem which was the heat sensor/thermistor, how do I test these before buying the part?
I hope this is enough info, I would appreciate some help please and thanks in advance!
