Where to buy L shaped wood for picture frames
20 Jun 2007
London
I'm just wanting to create my own handmade (simple) frame for a painting.
I can find places online costing a fortune (£55 a metre FF) but I just want to buy some angled wood and do it myself.
Does this type of wood have a special name (to help my search abilities)
Or anywhere in London (south/central) that sells it/similar
Buy some pine or ramin beadings from Wickes and glue and mitre to the size required
Blup
Ramin and beading arent L shaped so it won't work with what I need to do. Thanks for the suggestion though
Check out
£7.50m ex vat (and bar postage)- it was the first site that I came across- others might be better quality.
I you do decide to do your own framing, you need to factor in the cost of a decent saw, plus the mitre insertion tool
Check out
This is perfect thanks.
Check out
They do a cutting services have which is great so I'll use that to save my hassle
Can I ask what a mitre insertion tool is?
Mitres are often secured using fixings like corrugated fasteners
which can be inserted using a special hand tool
or L-shaped mitre fasteners
which can be set with a hand setting tool (as above) or using a bench top machine
These fasteners are both designed to pull the corners together tighty as you insert them. If mitre joining it by hand you generally need to set-up a corner jig of your own (basically two lengths of 2 x 1 softwood batten fixed onto a piece of plywood or MDF at right angles to hold the frame corner whilst you join it together). There are also kits which include a jig to do this, like the Charnwood kit
For smaller lightweight frames you can often join the mitres with hot melt glue, although it isn't always the most reliable method of joining stuff and it isn't strong enough for larger/heavier frames
...£26 for a chop-service which I'll glue myself...
A minor word of caution about glueing frames - as a technique it works for small, light frames with simple contents - add glass, a matte board, a backing board, etc and as the weight increases glue alone is less likely to work, which is why they invented those corner clips and corrugated fasteners I showed above. Maybe worth mentioning that for glazed pictures or mirrors mechanically securing the mitres is also a safety issue. With you on the DIY bit, though (y)
Oh yep, your earlier post was great with info for fastening, which I am defo taking note of (inadition to the gluing)
Luckily no glass involved this time.
How big ?
