Hi there, I just wanted to check it's not something I can check before I get an engineer out...
Basically the system boiler isn't heating the water for the hot water tank as hot as it used to.
Details: Worcester Bosch Greenstar 35 CDi Classic, about 4 years old, serviced annually by the local company that installed it, always worked well.
I noticed today that it just isn't heating the water going to the tank as hot as it used to. Thermostat on tank is up and clicked on, tap water power on boiler is set higher, not sure what else to look at,
Thanks for your thoughts, let me know if you want different info or pics.
pictures below:
pictures below:
