Basically the hot and cold pipes go to a bath which is being removed, and a shower put in it's place.Compression if I had to choose one, but a better job would be soldered. If you’re using on hot and cold then only use on on a pipe run no greater than twice the diameter, otherwise it’s a legionella risk, and always best to remove the section.
Yes, if capping off permanently on hot and cold pipes, if only temporary during refurb then it’s fine.The copper pipe is 15mm, so are you saying the pipe should be no more than 30mm long?
That's going to be fun tracing it back - a few more boards to come up methinks!Yes, if capping off permanently on hot and cold pipes, if only temporary during refurb then it’s fine.
Yep, that would work.Maybe use speedfit whilst removing the bath and then compression for permanent capping/fittings?
