What is OFF RT AND BUS on glow worm boiler?
Burner off isn’t used often, I’m told it’s for ufh or a condensate pump.
RT is usually mains voltage room thermostat
Ebus is for ebus controlled room thermostats used by the manufacturer, Glow Worm in your case. They “talk” to the boiler better.
Basically I fitted a wireless thermostat 3 years ago worked great. Removed it today and boiler turns on no problem buy boiler won't even try to fire up. What do I need to do?
Would this have something to do with it?
  • Thanks
Reactions: DP
Sorted. I Had to make a wire for the RT where I took out the wireless reciever. Panicked a bit. Handed my notice to landlord today. paying last month with deposit. Thought I was going to have to pay for a new boiler
Am I missing something?
That link is to run heating. Hot water is activated by combination part of the circuit when a hot tap is run.
That link would be required if boiler is a heat only appliance.
Every day is a skool day
