Squeeky creeky floor boards help!!!
13 Apr 2011
Antrim
Hi I am sure this has been asked 1000 times. I have bought a house and have squeeky and creeky floor boards. Really loud. I need to get it sorted before the carpets fitters get in. Any tricks or tips?
What type of floor? Many repairs? Condition of floor?
timber tongue and groove not sure how many repairs as just bought the bungalow. First thing that struck me when we viewed was how good the floorboards looked. We where close to sanding and varnishing. But decided to carpet instead
Screws every time. Pulls the boards down tight plus easier then if taking boards up in future.
Make sure no cables or pipes below where you want to fasten board!
I hear talcum powder is good to put down after screwing down is this right?
No, roll on deodorant is better
:eek::ROFLMAO::ROFLMAO::ROFLMAO:
The best solution is to screw them down properly with the right type and number of screws pulled up tightly. A good, if expensive, screw for this type of work is the Floor-Tite, as sold by places such as Toolstation. Even then there might still the possibility of some creaks if, for example, the sole plate of a wall has been nailed down onto a joist, but the nail has just grazed the joist because it was wrongly driven. Talcum powder doesn't do much - it's an old wive's tale - stopping movement by properly fixing is more likely to achieve a result
Better than floorboard nails?
Yes, because nails can move. Traditionally floors were nailed down with cut nails:
which because of their wedge shape tend to resist pull-out (and squeaking), but they are hard work to drive and require a heavier hammer than the more modern oval nails or French (round wire) nails. They are not much used these days. The problem with adding more cut nails or round nails, though, is that you risk splitting the boards (because you are nailing near the ends), whilst ovals may not achieve the amount of pull down you are after unless you drive them in pairs in divergent directions (i.e one angled slightly in away from the end of the board, the next angled in the opposite direction)
