Hi all,
We have a large-ish central heating system with 16 radiators. System boiler. We have recently swapped out the old vented cylinder and gravity fed CH system for an unvented cylinder and sealed CH system. Our issue that I need to sort is that the pressure gauge is consistently dropping around 0.05 bar a day.
As a bit of background, when we had it gravity fed I was regularly bleeding the upstairs radiator directly above the boiler- on a weekly basis. The water was always quite black so I thought it might possibly be some corrosion contributing to the issue, but we have had one or two plumbers round over the last couple of years to service and they suggested a small leak somewhere. We definitely have no visible leaks so if we do, I can only surmise that it is ground floor level under the floorboards.
For unvented we now have a magnetic filter and largely due to the above observations I requested a power flush. When bleeding the rads all comes out clear now. I have checked and rechecked all radiator connections. No patches on ceiling or floors. No obvious damp.
What would people generally recommend as next steps? Plumber/specialist leak detection company? A leak stop solution to add to the CH system? We are currently renovating the house albeit annoyingly I have already redone around a third of the downstairs flooring- but, I guess it could still be effectively surveyed at least from other rooms by taking out a floorboard or two.
Anything else obvious I can check? Boiler seems fine and is regularly serviced.
